deorto Posted September 13, 2008 Share #1 Posted September 13, 2008 the raido on my 84vr and my 89 vr will not switch to fm is there any way to fix this??????? Link to comment Share on other sites More sharing options...
Dano Posted September 13, 2008 Share #2 Posted September 13, 2008 If you can, you may need to pull apart the module these buttons are in and gently spray some contact cleaner in the buttons. Possible dirty contacts in there. Where is Chrisne IN? Dan (SE Indy) Link to comment Share on other sites More sharing options...
deorto Posted September 13, 2008 Author Share #3 Posted September 13, 2008 it's chrisney in. i'm in souh west indiana about 10 miles from owensboro ky Link to comment Share on other sites More sharing options...
MiCarl Posted September 14, 2008 Share #4 Posted September 14, 2008 If you can, you may need to pull apart the module these buttons are in and gently spray some contact cleaner in the buttons. Possible dirty contacts in there. (SE Indy) While you have it apart hit all the buttons with the cleaner. The ones that currently work will stop next week if you don't. Link to comment Share on other sites More sharing options...
mbrood Posted September 15, 2008 Share #5 Posted September 15, 2008 Yep, it sounds like the am/fm button is either stuck open or stuck closed... time for some cleaner. I wasn't so lucky, mine had green crud around them and I had to replace about 6 of 'em... went to a local TV/radio repair shop and he had about 50... and gave me 6 for a dollar... just watch the "height" of the shaft on any replacement, you can cut them down but they REALLY need to be all the "original" height or reassembly will find one or mure stuck closed (depressed). Link to comment Share on other sites More sharing options...
bongobobny Posted September 15, 2008 Share #6 Posted September 15, 2008 Man, does he still have any more switches?? I'll gladly clean out his stock of those switches. Can't seem to locate them very easily, especially at that price!! Link to comment Share on other sites More sharing options...
Guest superman Posted September 15, 2008 Share #7 Posted September 15, 2008 Don't mean to be the downer here but I had the same problem with my '88 when I bought it. After attacking the buttons with contact cleaner it made no difference. I had to replace the actual tuner unit inside the fairing and then all worked fine, hope this is not your problem is somewhat expensive fix. Link to comment Share on other sites More sharing options...
Guest Ken8143 Posted September 15, 2008 Share #8 Posted September 15, 2008 some times you can find a radio/tuner unit on e-bay for not too bad Link to comment Share on other sites More sharing options...
