Front Stableizer
Red Ryder
Check your steering head bearings . If they are set loose the front end will shack. You can set them on the tighter side because it is 3 wheels and does not lean any.ore. my 86 tri-wing kit did the same thing and i tightened up the steering head bearing and help very much. Give it a try. Good luck
Thank You Keith, I will check and tighten the front end. Later-
