Hi,
I'm new so hope I'm doing this right. Anyway, I just finished taking the back end of my 85 apart to get the gas tank out as I have a fuel leak. I drained the tank (lots of rust bits came out) and filled it with water to see if I could find the leak. So far it does not appear to be leaking.
The only reason I went after the tank was that I lose 1/2 tank of fuel in about two days with the petcock closed. Anyone know where else it could be leaking? The sending unit does not appear to be leaking and the petcock is brand new (changed it last fall as I thought it was leaking). Anyone else run into this? Could it be a seam that opens when the temp changes? Although I put cold water in and now the sun has heated it up pretty good.
Anyone try the POR-15 products to clean and seal their tanks? Anyone know where a good used dealer is that I could buy one from?
Thanks,
Ian
