BG Hawks Posted September 2, 2013 Share #1 Posted September 2, 2013 Finished up my little project. Always hated the way the trunk looked when I opened it up. No lining, the flimsy little mat and all my stuff laying around. Started off by tracing the mat on 3/16 plywood. Wanted to use a plastic sheet but did not have any and cope plastics was closed at the time. Using a trunk mat from Walmart (learned that from a previous post) I covered the plywood using Loctite double sided tape; holds 100 lbs. I than lined the sides with the tape and laid out the matt; cutting and trimming to make it fit. Built my organizer out 1/2 plywood and covered as well. The organizer and bottom are seperate and can be pulled out for access any time. My half helmet still fits no problem. Next goal is to add a light. This winter I will work on the saddle bags! Sorry about the grainy picture. Link to comment Share on other sites More sharing options...
Snaggletooth Posted September 3, 2013 Share #2 Posted September 3, 2013 Did my trunk a couple years ago with trunk liner from WW. Still holding up well. One of the best improvements I've done for traveling. Keeps everything where it needs to be. Wired mine for lights and power ports to for charging cell and camera also. Worth the effort. From my Droid wherever I may happen to be at any given moment. Link to comment Share on other sites More sharing options...
SARNA66 Posted September 3, 2013 Share #3 Posted September 3, 2013 trunk liner from ww? what is that? Link to comment Share on other sites More sharing options...
BG Hawks Posted September 3, 2013 Author Share #4 Posted September 3, 2013 Wally World Link to comment Share on other sites More sharing options...
