dingy Posted November 3, 2009 Share #1 Posted November 3, 2009 (edited) I am in the process of installing cruise control on my 1983 Venture Standard. I have purchased almost all of the items I need to do this upgrade from ebay. Prior to installing the parts, I will be disassembling the ones that I can and cleaning them. I have made the following write up of the process of cleaning the clutch side switch housing that came off of a 1988 Venture. The pictures show the switch completely removed from the bike. It is fairly lengthy, 47 pictures, but thorough. I would recommend removing switch from bike if you perform this cleaning. There are a number of small springs and ball detents that are very easy to lose unless you have a large well lit working area. If you are unable to open the PDF file, PM me with your email address and I will send it to you. I have detailed the throttle side switch in another thread. Picture below is of the switch detailed in this PDF file. 38050.pdf Edited February 14, 2016 by Freebird Link to comment Share on other sites More sharing options...
