loudad Posted June 9, 2019 Share #1 Posted June 9, 2019 2007 venture whenever turn signals are on I get all kind of static. Sometimes when driving it will happen also. Suggestions welcomed. Link to comment Share on other sites More sharing options...
RDawson Posted June 9, 2019 Share #2 Posted June 9, 2019 I would start by cleaning the audio plugs in the fairing and put a little dielectric grease on the rubber boots to keep moisture out. Check all your ground connections while you're in there, make sure they're clean an tight. The plugs are on the right side of the radio in the fairing in a large bundle. Link to comment Share on other sites More sharing options...
Tennessee Posted June 20, 2019 Share #3 Posted June 20, 2019 I'd bet money we're talking loose or off ground wire probably in the turn signal circuit, since it only happens with the signals. Link to comment Share on other sites More sharing options...
