Guest Brad25ca Posted July 15, 2008 Posted July 15, 2008 OK, I've gone through the whole system. I was getting an E1 & E4 error. I've soldered the connections in the control unit, traced every wire for continuity, relay test was done, was able to get the pump to spin independently, but still, the system won;t work! It reads the psi, but when I press to increase or decrease, I hear the relay and the solenoid click but nothing happens. I've gone through every step in the service manual. What next? Does this mean that the control unit is faulty? At some point during this exercise, I was able to decrease the pressure using the CLASS unit, but had to manually inflate.... What's next?
rumn1 Posted July 16, 2008 Posted July 16, 2008 http://www.venturerider.org/forum/showthread.php?t=23069&highlight=class+system Look at this thread. The system is slow. In auto I push the front or rear, then wait for the pressure and L, M or H to display. Then push one of the other two buttons L, M or H to change pressures. The pressures are set per the service manual. The raise and lower on work in Manual mode. Still must push front or rear first. LOL.
Guest Brad25ca Posted July 17, 2008 Posted July 17, 2008 (edited) Ok, Got an E2 error, and from the diagnostic in the service manual, it seems like I have a bad relay, even thought the relay "passed" the test in the manual. Now the issue is my local shop, belive it or not, can't locate the relay on the microfiche. They are guessing at which one it is. Adn i just missed the right one on eBay!! Edited July 17, 2008 by Brad25ca
