Precious Posted June 17, 2025 #1 Posted June 17, 2025 An update. Since no one responded I took the headlight apart and yes, there is an inline fuse in the housing for the light bar. In my case the fuse is fine and I did get the lights working but as soon as I put the headlight back together they quit again. I suspect a break in the wire so will pickup a new fuse holder and once I get it working, will relocate the fuse to and easier spot to get at it.
Marcarl Posted June 18, 2025 #2 Posted June 18, 2025 22 hours ago, Precious said: An update. Since no one responded I took the headlight apart and yes, there is an inline fuse in the housing for the light bar. In my case the fuse is fine and I did get the lights working but as soon as I put the headlight back together they quit again. I suspect a break in the wire so will pickup a new fuse holder and once I get it working, will relocate the fuse to and easier spot to get at it. Maybe i can give you some insight into why no-one responded. They probably figured that you would get your answers from the other post. Suggest you post only once and once only to get more attention and replies.
Precious Posted June 18, 2025 Author #3 Posted June 18, 2025 Thank you for your input, you are one of very few who eve take the time to respond. Having said that, this far from the first time I have not received any response regardless of a single or double post. It's at time like this I question the value of paying for this site. One would think others have had similar issues to many issues I have posted about. I can't have the only older RSTD. On the bright side, I'm learning more and more about my bike and how to take of many of the issues. Again, thanks for your input.
