TonyLudwick Posted May 14, 2025 #1 Posted May 14, 2025 Greetings. My 2018 Yamaha Venture Trans Continental Gas Door wont open. Solenoid clicks when I press the button but door does not open. I have tried holding the door down and wiggling the door when pressing the button with no luck. Battery is fully charged. I removed the 2 screws at the rear of the housing, but the other 2 screws are underneath the door that will not open. Has anyone else had this problem? If so. how did you solve it? Any Ideas would be much appreciated. Regards, Tony
bpate4home Posted May 14, 2025 #2 Posted May 14, 2025 7 hours ago, TonyLudwick said: Greetings. My 2018 Yamaha Venture Trans Continental Gas Door wont open. Solenoid clicks when I press the button but door does not open. I have tried holding the door down and wiggling the door when pressing the button with no luck. Battery is fully charged. I removed the 2 screws at the rear of the housing, but the other 2 screws are underneath the door that will not open. Has anyone else had this problem? If so. how did you solve it? Any Ideas would be much appreciated. Regards, Tony I had a similar issue. I had to basically pry up with my fingers. Once I got it open I cleaned the latch well with brake cleaner and the applied some light oil/grease.
