cimmer Posted January 4, 2023 Share #1 Posted January 4, 2023 (edited) Just want to mention that I see a number of Ventureline Chrome Brake Rotor Covers listed on ebay right now. Be aware that you also need the special wheel spacer, item #3 on the attached file, for this items to fit properly on your Venture. The new items came with this as part of the kits but a lot of times the used ones dont as all they remove is the covers and not the spacer. So if you plan on buying these, we sure to ask the seller if they include the proper wheel spacer that goes on the front axle. You can check out this file for information about installing the covers.. https://www.venturerider.org/forum/applications/core/interface/file/attachment.php?id=23976&key=935b195b892b11a362d0b39fb4e0f03e Hope this helps.. Rick F. Edited January 5, 2023 by cimmer 1 Link to comment Share on other sites More sharing options...
