Stormy1900 Posted November 17, 2022 Author Posted November 17, 2022 Thanks I have it apart my question is I have read about this Twinkie thing in the v of the motor part of the breather it’s a cigar shaped o-ring can anyone explain this and we’re is located
RDawson Posted November 17, 2022 Posted November 17, 2022 Look between the front and rear cylinders on the block. The heat exchanger/Twinkie sets there, it looks like a Twinkie earning it that moniker. There are o rings and seals that can let water/oil mix. 1
megamile Posted March 6, 2025 Posted March 6, 2025 Oil in my coolant also; discovered 2 days ago. A lot of sludge. Ordered pump rebuild kit and seals but can find no info on twinkie including proper part name. Need seals and o-rings for it; can anyone help with name, part numbers, etc? 2011 Venture, 91,000 miles.
megamile Posted Saturday at 07:47 PM Posted Saturday at 07:47 PM Found parts; ordered used replacement. Still have to order o-rings and crush washers. Have heard that it is possible to remove without removing carbs; I hate to mess with the carb boots as I'm afraid they might be brittle and/or crack (106,000 miles) and lead to bigger more gnarly things. Also wondering if I placed new seals on water pump shaft properly... Replacing radiator, fan, possibly thermostat next week to prep for long trip Juneteenth; would like to check pump and Twinkie at the same time (I think pump will be easier with radiator out). I have to stop this oil in coolant thing before it causes anything more. Any advice is greatly appreciated; anyone in the Tampa area who might have knowledge and be willing to help would also be appreciated.
