FloridaKayaker Posted June 29, 2019 Posted June 29, 2019 I'm pretty much in need of an emergency fuel pump. I'm curious if there is a cross reference number to a Holley fuel pump that I can buy at AutoZone or Discount Auto Parts? Does anyone know of anything like this?
Du-Rron Posted June 29, 2019 Posted June 29, 2019 I'm pretty much in need of an emergency fuel pump. I'm curious if there is a cross reference number to a Holley fuel pump that I can buy at AutoZone or Discount Auto Parts? Does anyone know of anything like this? The facet 40178 is my 1st choice but a lot of folks have used the Mr gasket 42s which autozone should have in stock.
FloridaKayaker Posted June 29, 2019 Author Posted June 29, 2019 The facet 40178 is my 1st choice but a lot of folks have used the Mr gasket 42s which autozone should have in stock. https://www.venturerider.org/forum/attachment.php?attachmentid=116903 Is it just plug and play? What kind of rewiring? How does it mount? Joe
Du-Rron Posted June 29, 2019 Posted June 29, 2019 Is it just plug and play? What kind of rewiring? How does it mount? Joe https://www.venturerider.org/forum/showthread.php?86265-Mr-Gasket-Fuel-Pump-Conversion Also check the POINTS in your current fuel pump. You can file them flat or replace the points.
