10spd Posted March 13, 2017 Posted March 13, 2017 (edited) There ate 2 different sizes of bushings in the front forks. The top bushings are bigger than the lower set. Does anone know how to get the upper bushings. Or hav an extra set. Where i can get them. its The lowers bushings that I need. after a 2nd call to the shop. same questions as above. Sent from my SAMSUNG-SM-G920A using Tapatalk Edited March 13, 2017 by 10spd
MiCarl Posted March 13, 2017 Posted March 13, 2017 I assume you're talking about your 88. Upper bushing: 3JJ-23125-00-00 - METAL, SLIDE 1 Lower bushing: 3JJ-23171-00-00 - PISTON,FRONT FORK Partzilla has them in stock. If the shop you're dealing with doesn't know how to look them up it's time to find a new shop.
10spd Posted March 13, 2017 Author Posted March 13, 2017 I assume you're talking about your 88. Upper bushing: 3JJ-23125-00-00 - METAL, SLIDE 1 Lower bushing: 3JJ-23171-00-00 - PISTON,FRONT FORK Partzilla has them in stock. If the shop you're dealing with doesn't know how to look them up it's time to find a new shop. Yes they are for my 88. I ordered the bushing from Partzilla with help from them. After finding out 2 were right 2 were wrong. I did a little research & found out I needed the 3JJ-23171-00. They are on order. Thanks Micarl. this is another reason for the expense to be a member of this website. Everyone here is very helpful.
