Cruze Posted September 12, 2016 #1 Posted September 12, 2016 Hi guys, I have an 86 Royale . The class system was showing E4....solved that by resoldering the nine pins at the back of the plug. Now I have an E1 fault code.... How do I cure this one please....? Thanks in advance... Regards Kevin
Prairiehammer Posted September 12, 2016 #2 Posted September 12, 2016 Cruze said: Hi guys, I have an 86 Royale . The class system was showing E4....solved that by resoldering the nine pins at the back of the plug. Now I have an E1 fault code.... How do I cure this one please....? Thanks in advance... Regards Kevin "E1" error may encompass a broad range of defects. Faulty connections. Faulty discharge valve (solenoid). Low pressure sensor input voltage. (Low battery or low voltage due to poor connectors) Faulty pressure sensor. And finally, incomplete solder repair at the nine pin board connector.
Cruze Posted September 12, 2016 Author #3 Posted September 12, 2016 Thank you sir.... I'll work my way through those...!
mralex714 Posted September 16, 2016 #4 Posted September 16, 2016 Cruze said: Hi guys, I have an 86 Royale . The class system was showing E4....solved that by resoldering the nine pins at the back of the plug. Now I have an E1 fault code.... How do I cure this one please....? Thanks in advance... Regards Kevin Same issue with my 86, ended up changing the compressor assembly. About a year later I removed the system and added schrader valves and bought a portable 12v compressor from Harbor Freight for $9.00 and never looked back. and I can air up my tires if needed.
