Lug Nut Posted July 1, 2016 Posted July 1, 2016 Got the wheel tire and fender off, brake calipers tied up out of way...working on draining fork oil now. What is the easiest way to remove the fork covers (top and bottom)? I removed pinch bolts from neck, and removed the 2 bolts on the bridge that seem to secure the bottom fork covers. Do I need to loosen the fork nut? I am not tearing down the forks, just drained, flushed, and refilling with fresh oil. Edit / Delete Edit Post Quick reply to this message Reply Reply With Quote Reply With Quote Multi-Quote This Message
dbikers Posted July 11, 2016 Posted July 11, 2016 With the cover bolts off and all the other stuff that you say youve tsken off just slide the forks out of the triple clamps and voila...covers off
