Wilzhere Posted June 30, 2016 Posted June 30, 2016 (edited) Guys i need some help..Has anyone used these parts to rebuild a 83 ventures carbs, i dont need the float needles/ seats. just the gaskets. really just the jet block gaskets and 0-rings, all my float bowl gaskets are in good shape. these look identical .... 1985 [TABLE=class: fTbl] [TR] [TD][/TD] [TD]Yamaha[/TD] [TD]Vmax 1200[/TD] [TD] any ideas? I've tried punching my own gaskets with no sucess, cant find the right gasket material. Must be another YAMAHA trade secret.[/TD] [/TR] [/TABLE] [TABLE=class: fTbl] [TR] [TD]Thanks[/TD] [/TR] [/TABLE] [TABLE=class: fTbl] [TR] [TD][/TD] [TD][/TD] [/TR] [/TABLE] PLEASE JUNK THIS THREAD >>PROBLEM RESOLVED Edited July 1, 2016 by Wilzhere
snyper316 Posted July 25, 2016 Posted July 25, 2016 as a matter of fact i have thats what is in my carbs the float needle i believe is the wrong size for ours and that other piece i couldnt use either but i bought it for like 20 bux for all 4 carbs and mainly what i needed was all the gaskets... but if your gonna pull the carbs you might as well use everything you can and clean them out real good its what i did i didnt need the enrichers valve gasket but replaced it anyways
