10spd Posted January 31, 2016 Share #1 Posted January 31, 2016 [ATTACH]103268[/ATTACH I just noticed this. Does this mean my clutch master cylinder is broken? Sent from my SAMSUNG-SM-G920A using Tapatalk Link to comment Share on other sites More sharing options...
MiCarl Posted January 31, 2016 Share #2 Posted January 31, 2016 No. The tab on the switch is broken. Someone tried to glue it in place. With it hanging out like that your cruise control won't work and it'll probably start in gear without pulling the clutch. Link to comment Share on other sites More sharing options...
10spd Posted January 31, 2016 Author Share #3 Posted January 31, 2016 I have to push the clutch lever out for the cruise to work what switch is that that is broken Sent from my SAMSUNG-SM-G920A using Tapatalk Link to comment Share on other sites More sharing options...
Yammer Dan Posted February 1, 2016 Share #4 Posted February 1, 2016 Might take a try with some JB Weld to put it back in place but I'd be looking E-Bay. Link to comment Share on other sites More sharing options...
Sylvester Posted February 3, 2016 Share #5 Posted February 3, 2016 If you have to push the clutch lever out to get the Cruise to work, you have a problem with the clutch switch. Usually this only takes adjusting the clutch to rest forward. Link to comment Share on other sites More sharing options...
Yammer Dan Posted February 3, 2016 Share #6 Posted February 3, 2016 With the housing broken like that I would clean it up good. Make sure the switch is lubed good and JB Weld it back in place. Might work might not but it ain't working now??? Link to comment Share on other sites More sharing options...
