twowheeltexan Posted March 25, 2008 Share #1 Posted March 25, 2008 Just curious if anyone on the site has done a before and after dyno run on their second generation Venture or Royal Star after adding some or all of the following items to improve the performance : 1. Aftermarket slip ons. 2. K&N or other less restrictive air filter. 3. Dyna 3000 or other ignition mod. 4. Jet Kit. I am sure that many people on the site have done some or all of the above and if you didn't confirm the results with a dyno run what did the seat of the pants feel indicate after the mods. Link to comment Share on other sites More sharing options...
yamahamer Posted March 25, 2008 Share #2 Posted March 25, 2008 1. Aftermarket slip ons. 2. K&N or other less restrictive air filter. . I had one done after adding BUBS and K&Ns but it was an inertia test and was done in 5th gear "OD" it showed 74.9hp in 5.04 seconds and 82.49ft*lb in 1.92 seconds but like I said this was an inertia test not a real dyno. This is not bad when you think about it's in OD from 1341 rpm to rev limiter in 5.04 seconds. I do want to put it on a true dyno one day just to see. The 98 hp YAMAHA says you have is at the crank not the rear wheel. "Seat of the pants" AWESOME! Link to comment Share on other sites More sharing options...
