shuttlebug Posted January 24, 2015 Share #1 Posted January 24, 2015 I'm changing the heads on my 01 RSV, and I got the front cams to line up with the marks, but the rear cams are a little bit off. The flywheel has three marks for #1 TDC, looking at the book, it looks like the last mark (turning counterclockwise) is the one- But the marks are 1/2 tooth off on the cam. Two more marks to check, but with my wrist hurt, I can't do much more trial and error Please help, the Yamaha engineers have got my goat! Link to comment Share on other sites More sharing options...
shuttlebug Posted January 26, 2015 Author Share #2 Posted January 26, 2015 Nobody has taken a 2nd gen RSV apart? Back to guessing Link to comment Share on other sites More sharing options...
MikeWa Posted January 26, 2015 Share #3 Posted January 26, 2015 Clymer manual M374 'Yamaha Royal Star 1996-2003' has a fairly detailed procedure for engine disassembly. If all else fails make your own timing marks before disassembly. But I seriously recommend getting the manual. Mike Link to comment Share on other sites More sharing options...
Neil86 Posted January 26, 2015 Share #4 Posted January 26, 2015 The tensioner is not pressing on chain at this point? Link to comment Share on other sites More sharing options...
shuttlebug Posted January 26, 2015 Author Share #5 Posted January 26, 2015 I tried it today on the 2nd mark- which today looks more like the book than it did a few days ago... I think I hit my head too hard in the wreck o_O The marks line up better now. Thank You Brian B Link to comment Share on other sites More sharing options...
Neil86 Posted January 27, 2015 Share #6 Posted January 27, 2015 The first 2 marks as you rotate CCW are the firing range for #1, the 3rd mark (last to rotate under) is the TDC mark. Link to comment Share on other sites More sharing options...
