DblTrbl Posted June 25, 2014 #1 Posted June 25, 2014 Just got my Mic Mute kit for my RSV. Says I need to remove gas tank? I'm guessing not everyon removed the tank to run the wires.... Also, is there an alternate location for the control module since I just added a Utopia backrest I don't have room between the seats.
djh3 Posted June 25, 2014 #2 Posted June 25, 2014 Gas tank is easy 3 bolts. Besides then you can install a ignition by-pass relay so the switch dont burn up. lol I thought they mounted the box for that up under the fairing.
Kregerdoodle Posted June 25, 2014 #3 Posted June 25, 2014 remove tank so that the wires can be ran correctly, the box and fuse mount just under the front of the back seat...
