jurob Posted June 18, 2014 #1 Posted June 18, 2014 Original broke and was not an issue. New factory replacement and it will sometimes not return all the way and will activate the brake light, brake is not engaged only the rear light is coming on. I have played with varying amounts of free play and have even installed a small spring between the plunger, lever and screw with no luck. Brake light will be activated till I push the lever forward just a little bit. If I am parked it will stick approx 1 of 10 times. Spring seemed to help a little. Cruise control won't activate when this happens. Hope this makes sense. All tips appreciated.
jurob Posted June 18, 2014 Author #2 Posted June 18, 2014 Thinking out loud, Maybe the brake light switch on the lever is adjustable?
Guest tx2sturgis Posted June 18, 2014 #3 Posted June 18, 2014 Whatever force caused it to break may have damaged or bent something. Or it may just need some lube. Try some WD-40 in there.
M61A1MECH Posted June 18, 2014 #4 Posted June 18, 2014 Maybe you have the jam nut to tight and the lever is binding in the clevis. Is the return spring item 4 in this IPB installed? http://www.yamahasportsplaza.com/oemparts/a/yam/50045f62f8700209bc794de9/handle-switch-lever
jurob Posted June 18, 2014 Author #5 Posted June 18, 2014 I'm assuming the spring (#4) is held in place by the set screw and nut? Then no, I don't have that and that's why I added a spring, but apparently mine is not strong enough. Tks for the pic, looks like I will order the correct spring! Tks M61A1!
jurob Posted June 18, 2014 Author #6 Posted June 18, 2014 Looking harder at the pic, it looks like its right next to the set screw. Getting ready for work, but I will check and see if the spring is installed and get back. Hopefully it's not installed and a less than $2 repair would be nice:)
jurob Posted June 18, 2014 Author #7 Posted June 18, 2014 No spring, will be ordering one now. Tks everyone.
