When I removed the old carb joints from the #2 and #3 cylinders oil came out of the outside bolt holes. Is this normal? I used thread locker when I put the bolts back in. Will this seal them so I don't have an oil leak? Anti freeze came out of the outside bolts on #1 and #4 cylinders. Is this also normal? Should I use a special sealer on the bolts?
Thanks in advance for all your help.
Jim
No Jim,
You do not have oil issue. These bolts go into the oil gantry to the cams.....so make sure you use the short zinc coated allen bolts rather than any of the other longer bolts, or you will close off the oil passage to the cams. And don't worry about any thread sealant.
Rick
Jim
