mralex714 Posted November 7, 2013 #1 Posted November 7, 2013 Is the starter from a 91 Vmax a 4 brush?
Venturous Randy Posted November 7, 2013 #2 Posted November 7, 2013 Yes, it should be. Look on the outside of the starter and see if it has screws that go into the outside. The V-Max starter should not have screws. RandyA
dingy Posted November 7, 2013 #3 Posted November 7, 2013 91 might be a 2 brush. I think they went to 4 brush in 93. I will check tonight when I get home. Gary
dingy Posted November 9, 2013 #4 Posted November 9, 2013 Finally remembered to check parts fiche and it does look like change was made to 4 brush starter on VMax's in 1993. The brush set p/n's changed that year. Yamaha doesn't list numbers for housings. Couple of part fiches I checked all list same number for complete starter assy, but I think all they are showing replacement as a 4 brush. Gary
mralex714 Posted November 9, 2013 Author #5 Posted November 9, 2013 dingy said: Finally remembered to check parts fiche and it does look like change was made to 4 brush starter on VMax's in 1993. The brush set p/n's changed that year. Yamaha doesn't list numbers for housings. Couple of part fiches I checked all list same number for complete starter assy, but I think all they are showing replacement as a 4 brush. Gary That's what I thought. Thanks
Venturous Randy Posted November 9, 2013 #6 Posted November 9, 2013 Like I said before, I learn something on here everyday. RandyA
