fng985 Posted September 4, 2013 Share #1 Posted September 4, 2013 (i posted this in the welcome section to and said be better to put here) Hello all I'm new to forum and new to Yamaha ventures. I got a 1983 Venture (momma said couldn't buy anything else so traded for couple guns) anyway its not the prettiest (work on that later) but runs good and only needed a battery or I thought so until I went on her madden voyage and found out didn't have 4 or 5 gear ugh! Well after searching on here seems like simple fix and help from Yamamike I have a couple links. But does anybody know what the part number is for the shift pin/basket/whatever is called (changes the bent over flap type to hold the pins in to the cast version)that upgrades from 1st generation to the vmax version or 2nd generation Venture (whichever is better). Thanks for any help. O iI did find the thread on changing it and the 2nd gear issue but just cantcan't find the part numbers. Link to comment Share on other sites More sharing options...
icebrrg3rd Posted September 4, 2013 Share #2 Posted September 4, 2013 Just go to a parts site and look up a newer V-Max (like a 2000) and you will find the part number. For example, Cheap Cycle Parts dot com: http://www.cheapcycleparts.com/oem-parts/yamaha/2000/vmx12m-v-max/shift-cam-fork The numbers I got off there was: Item #6: 4NK-18185-00-00 for the segment (what they call the shifter cam) Item #7: 93604-12037-00 for 5 of the dowel pins Item #13: 93604-16092-00 for the 6th dowel pin Double check to make sure I didn't typo. You need new pins as the ones you have for the shifter cam that has the bent metal retainer are longer than the one required for the new cam. I was cheap and just used a cut-off wheel on my dremel to make them shorter. Might need a new screw, depending on how much you bugger up the head when you try removing it. That's 90151-06013-00, item #8 Good luck with it, from a fellow '83 rider. -Andrew Link to comment Share on other sites More sharing options...
fng985 Posted September 4, 2013 Author Share #3 Posted September 4, 2013 sweet thanks for the info, will order tomorrow........ Link to comment Share on other sites More sharing options...
fng985 Posted September 5, 2013 Author Share #4 Posted September 5, 2013 I ordered parts from partzilla and should be here by early next week. I paid 53$ for the segment all 6 dowel pins and a new screw. Thought about it afterward but probably going to need some type of gasket ugh thats my luck. I will order that next I reckon. This forum rocks for info and people. Link to comment Share on other sites More sharing options...
icebrrg3rd Posted September 5, 2013 Share #5 Posted September 5, 2013 Depending on how well it stays together, you could re-use it. I've had my cover off several times and reused the same gasket. -Andrew Link to comment Share on other sites More sharing options...
fng985 Posted September 20, 2013 Author Share #6 Posted September 20, 2013 All is good in the shifting world now thanks to my fellow ventures . It was a lot easier repair then I thought except the part where I put couple parts backward and left some out. It only took 5 Times to get it right and now I'm cruising . PS no matter how many times you tell a 8 year old see that part right there the black one no the other black one they still don't understand. Link to comment Share on other sites More sharing options...
Trader Posted September 20, 2013 Share #7 Posted September 20, 2013 except the part where I put couple parts backward and left some out. It only took 5 Times to get it right: Welcome to my world! That's the norm for ANYTHING I do it seems. :bang head::bang head: Link to comment Share on other sites More sharing options...
Yammer Dan Posted September 20, 2013 Share #8 Posted September 20, 2013 After you do it a few times you can get it down to 4 with luck 2 or 3.... Link to comment Share on other sites More sharing options...
Venturous Randy Posted September 20, 2013 Share #9 Posted September 20, 2013 (edited) I ordered parts from partzilla and should be here by early next week. I paid 53$ for the segment all 6 dowel pins and a new screw. Thought about it afterward but probably going to need some type of gasket ugh thats my luck. I will order that next I reckon. This forum rocks for info and people. And just think, I paid $49 bucks for a complete 03 RSV trans that also had the shift cam with the upgraded end that is made as one piece and does not have the pins to worry about. This is what the new one looks like. RandyA Edited September 20, 2013 by Venturous Randy Link to comment Share on other sites More sharing options...
Yammer Dan Posted September 21, 2013 Share #10 Posted September 21, 2013 And just think, I paid $49 bucks for a complete 03 RSV trans that also had the shift cam with the upgraded end that is made as one piece and does not have the pins to worry about. This is what the new one looks like. RandyA Quit rubbing it in!! I Forgot!!:rotfl: I glad you got it. I didn't remember it til next morning! Link to comment Share on other sites More sharing options...
fng985 Posted September 23, 2013 Author Share #11 Posted September 23, 2013 That's what mine looks like the pins go through the back and rest against the "star" right? Its a lot smarter design then the original for sure. Link to comment Share on other sites More sharing options...
