YamahaWoodsey Posted September 3, 2013 #1 Posted September 3, 2013 I've got about 2500 miles on my RSMV and when I first got it had about 15 grand on her . I noticed the clutch clunking a little when you put her in gear 1st to 2nd the most so I changed the oil with Yama Lube 20w50 and a new filter and it took a lot of it out so my ? would be . Is it time for the clutch up grade or Is this the normal for it .
Sylvester Posted September 3, 2013 #2 Posted September 3, 2013 I would go with a clutch upgrade. Very easy to do and there are two that are great. Barnett makes a very good unit and there is the PCW version. There is one sold here on this site and has great reviews. You most likely do not need new discs. My RSV has near 180,000 with the original discs. Just get the spring upgrade and in some instances the full rear disc.
