venture83_98 Posted August 27, 2013 #1 Posted August 27, 2013 (edited) for my '86 VR...... -- and the tough one: stock needles and main jets (to replace the non- stock ones on there now) I know I will probably need a set of carbs to get the needles, so they dont need to be pretty. I would just buy a nice set and be done with it, but thats not in the budget. Anyone interested in some custom high flow intakes?????????? Edited August 28, 2013 by venture83_98 updated list
KIC Posted August 27, 2013 #2 Posted August 27, 2013 Are the intake manifolds on an 84 the same for his 86 ?
venture83_98 Posted August 27, 2013 Author #3 Posted August 27, 2013 KIC said: Are the intake manifolds on an 84 the same for his 86 ? Just looked them up. They appear to be the same numbers
MiCarl Posted August 27, 2013 #4 Posted August 27, 2013 FULL SET OF NEW CARBURETOR HOLDERS INCLUDING O-RINGS Enter "VentureRider" in the coupon code box at check out for 15% off.
Yammer Dan Posted August 27, 2013 #5 Posted August 27, 2013 Anyone interested in some custom high flow intakes?????????? Would like to see how they done that.
Yammer Dan Posted August 27, 2013 #6 Posted August 27, 2013 KIC said: Are the intake manifolds on an 84 the same for his 86 ? 83's are different. I have a set not sure what from. I think 83 had nipple on it for Boost??Have to do some looking.
KIC Posted August 27, 2013 #7 Posted August 27, 2013 I just took a set off of one of my 84 parts bikes. They look the same but... somebody will have to make the final decision. You can have them if you want them. ...if they will work..
KIC Posted August 27, 2013 #8 Posted August 27, 2013 I also have a set of carbs off of one 84 that I have had trouble getting the sliders out of, but the slide needles are OK. Which are the main jets ? PAJ1 or Pilot Air Jet 1 PAJ2 ? The Main Jet Air Bleed. ?
venture83_98 Posted August 28, 2013 Author #9 Posted August 28, 2013 KIC said: I also have a set of carbs off of one 84 that I have had trouble getting the sliders out of, but the slide needles are OK. Which are the main jets ? The 1200 and 1300 have different size jets , and the needles have different numbers also. So, I would needs parts from a 1300.
venture83_98 Posted August 29, 2013 Author #11 Posted August 29, 2013 KIC said: Did you want the manifolds ? Someone offered a set up before you said you had them also. Thanks for checking. All I need now are the needles and some jets. Any ideas? The needles are listed as discontinued/ unavailable.
