Guest gregs02 Posted February 22, 2008 Posted February 22, 2008 has anyone ever installed an EQ on there bike thats not powered,,the Pryamid 403G that Freebird installed has a 100 watt amp built into it,what i need is info on an install on a passive EQ ( no power ) that i can use to run the system with a external amp , much like a system in a car ,,I have Polk audio EX2540 Component speakers front and rear,,alpine 4 ch amp,,and a bazooke 8" tube ,,channels 1 and 2 on the amp are powering the front and rear speakers and channels 3 and 4 on the amp are bridged to power the tube sounds really great,,,but there's no way to EQ the sound to make it sound awesome ,,,,
yamahamer Posted February 22, 2008 Posted February 22, 2008 how is your amp inputs? high level in or did you convert to RCA's
Guest gregs02 Posted February 22, 2008 Posted February 22, 2008 I used a HI-LO converter , taped into the rear speaker wiring,,
yamahamer Posted February 22, 2008 Posted February 22, 2008 Then you should only have one problem.....finding somewere to mount it as long as your converter is adjustable to get all the power out.
Guest gregs02 Posted February 22, 2008 Posted February 22, 2008 looking to see who has made brackets for there amp.
