cruzin123 Posted May 9, 2013 Posted May 9, 2013 I have a 1999 Venture and have noticed on occassion that a small amount of coolant leaks from these rubber drain plugs behind the covers on the cylinders. Does anyone have more information, like Yamaha part numbers to order these? And looks like they pull out easily, so probably not too big of a project, just top up the coolant at the end. I have read that a dime will add some extra pressure to stop the leaks but since the bike is from 1999, I want to replace all 4.
Guest Posted May 9, 2013 Posted May 9, 2013 Im about to do mine in a few minutes. You use the top tip of a spark plug, the ones with threads to pull the old plugs out. Make sure you drain your fluid first. Ill post the numbers later.
Guest Posted May 9, 2013 Posted May 9, 2013 See you already have the part numbers. you need 4 of them. Just finished mine. I thought the system was drained but a fair amount of coolant did come out. Piece of cake....
cruzin123 Posted May 14, 2013 Author Posted May 14, 2013 Everyone's answer really helped, I appreciate it.
pofarm Posted May 14, 2013 Posted May 14, 2013 I just did mine, too. I used two spark plugs, one to remove the old plug and one to install the new one. That way I lost a minimal amount of coolant.
Sexagenarian Posted May 11, 2018 Posted May 11, 2018 I know it has been a long time since this topic resurfaced, but I needed to find the part number for the drain plugs. I did a search for cylinder drain plugs and this thread came up. Saved me gobs of time trying to find that little plug in all the parts diagrams. This thread alone was worth the renewal fee for this site. Members on this site have and always will --- rock !!! --Wayne
7 lakes Posted May 12, 2018 Posted May 12, 2018 Check your local dealer for those too, i got them from my dealer for about 2 bucks apiece.
