jdog910 Posted March 10, 2013 Share #1 Posted March 10, 2013 I bought my ignition awhile back, programed it once and lost the cd that came with it. anyway, i downloaded the v80 software from ignitech and tried to load a new map and it says the v80 software is not compatible with the ingnition i have (v88) so the program button is greyed out. any body have the v88 version? or know whats going on? Thanks guys!! Link to comment Share on other sites More sharing options...
dingy Posted March 10, 2013 Share #2 Posted March 10, 2013 I bought my ignition awhile back, programed it once and lost the cd that came with it. anyway, i downloaded the v80 software from ignitech and tried to load a new map and it says the v80 software is not compatible with the ingnition i have (v88) so the program button is greyed out. any body have the v88 version? or know whats going on? Thanks guys!! PM me an email address and I will send you V88. I have to zip it or it won't go through email. There was a firmware/hardware change from V80 to V88, they are not compatible. You can load a V80 map file into V88 and it will update it. Gary Link to comment Share on other sites More sharing options...
jdog910 Posted March 10, 2013 Author Share #3 Posted March 10, 2013 Pm sent...thanks man! Link to comment Share on other sites More sharing options...
jdog910 Posted March 11, 2013 Author Share #4 Posted March 11, 2013 loaded the map from dingy ...wow!! what a change!! all the issues i thought were carb problems are gone.. if i had to pull those carbs off one more time I was sending the bike to the smasher! you guys are the best on here and cant thank you enough! Link to comment Share on other sites More sharing options...
KISA Posted October 11, 2013 Share #5 Posted October 11, 2013 Here fresh v88 https://app.box.com/s/mtzjtlirkdynev2lbdj1 Link to comment Share on other sites More sharing options...
dingy Posted October 11, 2013 Share #6 Posted October 11, 2013 Here fresh v88 https://app.box.com/s/mtzjtlirkdynev2lbdj1 Do you have any dyno runs with map you uploaded? What bike are you using it in? I see rev limiter at 9,500 which says VMax heads at a minimum. Are you using stock vacuum sensor? I will try it at some point. Different, but worth a try. Thanks for sharing !!! Gary Link to comment Share on other sites More sharing options...
KISA Posted October 11, 2013 Share #7 Posted October 11, 2013 Run small, only around the city, about 100 km. I wasn't in time any more, became cold and to streets there were hungry bears ( I use on XVZ13 1986. MAP sensor isn't established. Recently I received Ignitech, it is an insertion I was on a disk, completely factory. So because of small run while anything certain I can't tell. Share, please, other castom firmware) Link to comment Share on other sites More sharing options...
