venture83_98 Posted May 17, 2012 Share #1 Posted May 17, 2012 Anybody have a jet block gasket for an 83? I probably have to swap another carb body out. I got everything back together and on the bike, and got it started. I was then checking that all the mixture screws were set the same. They all turned execpt for one. I could feel the screwdriver slipping so I took a look. The head of the screw was starting to strip out. I tried a few more times to get it out, but it would not budge. Then I tried an easyout, which broke. They must have had The Hulk put this screw in. It will not budge. Luckily, I have a spare carb body, already soaking in the parts washer. Just need a gasket to swap the jet block into the new carb. Also, anyone in Columbus, Ohio have a carb sync tool to use? I have an old Motion Pro mercury set, but I loaned it to someone a few years ago, and they were kind enough to let it fall over and it lost about half of the mercury. Pretty sure there is not enough left to use it properly. Thanks in advance Link to comment Share on other sites More sharing options...
