Guest tjday Posted May 9, 2011 Share #1 Posted May 9, 2011 Just bought a 2000 Royal Star Venture. Everything works like a dream. Only issue that I seem to have is that the CB will not come on. When I push the CB button, nothing happens. Anything jump out that I might need to check first before I bring it to the dealer? Does the CB have separate fuses? Thanks, Jason Link to comment Share on other sites More sharing options...
ken Posted May 9, 2011 Share #2 Posted May 9, 2011 Check the connection. The CB is located under the trunk. Remove the four bolts that attachs the trunk to it's bracket. Once you remove the trunk you will see a black box with two rubber straps. Remove the straps and lift off the lid and you will see the CB unit. Make sure it's pluged in. You may also have to pull the fairing and check the connection inside. Both are very easy jobs. Should only take about 15 minutes each. Link to comment Share on other sites More sharing options...
