Rocket Posted November 12, 2007 Share #1 Posted November 12, 2007 Today, I have made an inquiry to J&M, about their JMCB2003 for connecting into the 1st gen VR Mk1 amp. I am awaiting their reply back, will update as I have more info to pass on. But here is what I had sent them "A few of us 1st Gen Venture Royale (1200cc early model 83-85) owners from http://WWW.VENTURERIDER.ORG, have been looking at adding CB onto our bikes. It is difficult to find all the components needed, for the optional OEM CB. Is it possible to patch your JMCB2003, into the din jack of the OEM amp (right angle plug required), that is provided for an optional CB. The bike is equipped with AM/FM radio, cassette deck & intercom when your YV-41 interface cables are installed, this all passes through the OEM amp. If I remember correctly it is a 6 pin din jack for the CB in the amp, if needed I will go to where the bike is stored for the winter & check. I am not sure which model would be best for this adaption, probably the dual or the Honda GL1500, as some will let the wife talk on the CB. " Link to comment Share on other sites More sharing options...
muffinman Posted November 13, 2007 Share #2 Posted November 13, 2007 Rocket here is a picture of the unit from my 84 so you wont have to pull your scoot apart to count connector pins. Jeff Link to comment Share on other sites More sharing options...
sarges46 Posted November 13, 2007 Share #3 Posted November 13, 2007 Hey Paul You need to contact Hugbare. He is a cb/radio guru. Link to comment Share on other sites More sharing options...
