superscouser Posted August 20, 2010 Posted August 20, 2010 After putting the carbs back on in the process of rebuilding after the second gear repair, a couple of them are leaking slightly out of the drain hoses. The drain screws are fairly tight (don't want to over tighten). Any tips/thoughts on how to stop the drips? Amazing how a little gas can stink out the whole garage... driving the Mrs nuts. Other than the leaking carbs, so far no other leaks that I can see ... fingers crossed. TIA
Yammer Dan Posted August 20, 2010 Posted August 20, 2010 If you haven't ran fuel threu them much yet they may just need chance to settle down. Not too early for Sea-Foam. I would use a little during Break-in. Or some Marvel Mystery Oil would be good.
