naturbar Posted August 19, 2010 Share #1 Posted August 19, 2010 i've used the search button on here but cannot get info i need. i know i've seen it discussed many times ..... 2007 RSTD how much oil do you use @ oil change ?? Link to comment Share on other sites More sharing options...
flb_78 Posted August 19, 2010 Share #2 Posted August 19, 2010 3.75qts Link to comment Share on other sites More sharing options...
LilBeaver Posted August 19, 2010 Share #3 Posted August 19, 2010 3.75qts 3.74999 Qts. :witch_brew: Link to comment Share on other sites More sharing options...
Guest tx2sturgis Posted August 19, 2010 Share #4 Posted August 19, 2010 i've used the search button on here but cannot get info i need. i know i've seen it discussed many times ..... 2007 RSTD how much oil do you use @ oil change ?? With a new filter, it will take about 3.5 quarts, maybe a tad more. Put 3 quarts in, run the engine for a minute to fill the filter, then put in about 1/2 quart. Run the engine again. Check your sightglass with the bike level, and add till its about half way up the sightglass. Link to comment Share on other sites More sharing options...
Guest tx2sturgis Posted August 19, 2010 Share #5 Posted August 19, 2010 Ok...I have to ask...are you guys using a measuring cup or what? Link to comment Share on other sites More sharing options...
flb_78 Posted August 19, 2010 Share #6 Posted August 19, 2010 I just use a 1 gallon jug of Rotella. Plop the bike on the centerstand and fill it to the top line. Start it, shut it off and refill to just below the top line. It leaves about a 1/4" of oil in the jug. Link to comment Share on other sites More sharing options...
naturbar Posted August 19, 2010 Author Share #7 Posted August 19, 2010 With a new filter, it will take about 3.5 quarts, maybe a tad more. Put 3 quarts in, run the engine for a minute to fill the filter, then put in about 1/2 quart. Run the engine again. Check your sightglass with the bike level, and add till its about half way up the sightglass. 3.5 qts vs 2.75 qts is quite a difference - why the discrepancy? Link to comment Share on other sites More sharing options...
flb_78 Posted August 19, 2010 Share #8 Posted August 19, 2010 I think you mean 3.5 vs 3.75 Link to comment Share on other sites More sharing options...
naturbar Posted August 19, 2010 Author Share #9 Posted August 19, 2010 I think you mean 3.5 vs 3.75 correct - i misread the original post as 2.75 - in this case the 1/4/qt. should not be an issue - thanks guys !! Link to comment Share on other sites More sharing options...
LilBeaver Posted August 19, 2010 Share #10 Posted August 19, 2010 3.5 qts vs 2.75 qts is quite a difference - why the discrepancy? I think you mean 3.5 vs 3.75 FLB - you use the longer (3.5"?) Purolator filter, correct? That could account for the 8 fl. oz (.25 qt) of a difference. I use the shorter filter and, like TX2Sturgis, end up with 3.5 qts +/- .25qt. Link to comment Share on other sites More sharing options...
CMIKE Posted August 19, 2010 Share #11 Posted August 19, 2010 Ok...I have to ask...are you guys using a measuring cup or what? Now why did you ask that? I do...7 of the 16oz Ratio Right measuring cup and then 6.5 ozs usually comes just about right. Old motocross racing thing I guess. On the 2 strokes you had to loosen a screw to see if the oil level was right or dump the premeasured amount in and GO. Sorry it is the way I am wired. Link to comment Share on other sites More sharing options...
flb_78 Posted August 19, 2010 Share #12 Posted August 19, 2010 FLB - you use the longer (3.5"?) Purolator filter, correct? That could account for the 8 fl. oz (.25 qt) of a difference. I use the shorter filter and, like TX2Sturgis, end up with 3.5 qts +/- .25qt. yep, plus I fill mine to the top line instead of the center of the glass. Link to comment Share on other sites More sharing options...
Guest scarylarry Posted August 19, 2010 Share #13 Posted August 19, 2010 yep, plus I fill mine to the top line instead of the center of the glass. When I fill to the top line it will burp oil out the vent tube, so 1/2 to 3/4 and no oil burping Link to comment Share on other sites More sharing options...
