CaliforniaRSV Posted July 6, 2010 #1 Posted July 6, 2010 (edited) I installed a Chrome Glow LED light Bar and it looks great and the brake light is great. My problem is the turn signals are only about half brightness. I checked the voltage on the turn signal wiring and only about 6 volts is coming through. Does anyone know why I would have only 6 volts to the turn signals? I checked it all the way back to the harness just behind the battery. Is there only supposed to be 6 volts to the turn signals and if so how to I get 12 volts to the turn signal wires on the Array? Edited July 6, 2010 by CaliforniaRSV
Wizard765 Posted July 6, 2010 #2 Posted July 6, 2010 CaliforniaRSV said: I installed a Chrome Glow LED light Bar and it looks great and the break light is great. My problem is the turn signals are only about half brightness. I checked the voltage on the turn signal wiring and only about 6 volts is coming through. Does anyone know why I would have only 6 volts to the turn signals? I checked it all the way back to the harness just behind the battery. Is there only supposed to be 6 volts to the turn signals and if so how to I get 12 volts to the turn signal wires on the Array? I added LED turn signals and also noticed they were dimm so I put relays in for those and powered them directly from the battery. Worked very well and now the signals are much brighter.
CaliforniaRSV Posted July 6, 2010 Author #3 Posted July 6, 2010 Good idea, I wondered about using relays. I don't have much experience with them, are there specific relays to be used with turn signals? What size did you use?
dray Posted July 6, 2010 #4 Posted July 6, 2010 http://www.easternbeaver.com/Main/Elec__Products/Relays/relays.html here ya go!
CaliforniaRSV Posted July 6, 2010 Author #5 Posted July 6, 2010 Do the 20 amp micro relays work fine for the turn signals? How are they wired? Do you just trigger them with the turn signal wire? Also I need to add a relay for a new electric horn, will another 20 amp micro relay work for it is well?
