Guest TCB1 Posted October 9, 2007 Posted October 9, 2007 Hey guys I have an 83 venture and i am looking at getting new mufflers for it i have a set from an 86 that are available to me but i want to make sure they will fit? does anyone know? they look the same to me but i want a second opinion. Thanks
Rocket Posted October 9, 2007 Posted October 9, 2007 Hey guys I have an 83 venture and i am looking at getting new mufflers for it i have a set from an 86 that are available to me but i want to make sure they will fit? does anyone know? they look the same to me but i want a second opinion. Thanks You will need to modify the mounts. But aside from that, they fit quite nicely.
Guest TCB1 Posted October 9, 2007 Posted October 9, 2007 when you mean modify do u mean cut bend weld etc, or what kinda work am i looking at getting into?
Rocket Posted October 9, 2007 Posted October 9, 2007 when you mean modify do u mean cut bend weld etc, or what kinda work am i looking at getting into? I had cut off the outward portion from the vertical tabs, used longer bolts with lock nuts. The upper part of the mounts are different, from the early ones & you may come up with a different method. But this was my quick & dirty solution to the mounting differences.
