finfan125 Posted March 9, 2010 Share #1 Posted March 9, 2010 Hello everyone This past weekend I installed Kuryakyn's 4710 run turn and brake controller on stock signals and also installed the signal dynamics light bar and now when i ride my radio cuts out and starts to squeal maybe two or three time per song randomly. I payed attention and no certain thing I do causes it.When I got back from my test ride I let my bike sit in the garage and left the radio playing and it wouldn't do it while just sitting there. Any suggestions????? Link to comment Share on other sites More sharing options...
Owen Posted March 9, 2010 Share #2 Posted March 9, 2010 Two Din connectors under the passenger seat, clean and apply dielectric grease. Also behind the front faring is a cluster of about 5 more Din connectors, do the same to them. Most of the intermittent problems I have seen with audio on these bikes can be cured with these steps. If it does not cure you problem now, it will surely prevent others later, especially if you ride in the rain. Link to comment Share on other sites More sharing options...
