I have a Iphone 3g in an OtterBox case. I know RAM makes a mount but all that is pictured is an Iphone without the protective case. Anybody have one mounted or any solutions? Thanks in advance!
:322:
Thanks, I looked at that box also but it wont allow you to use the Iphones touch screen to advance or pause, etc.
The description says "It has a flexible clear membrane front, which allows operation of buttons on the device inside the case."
I'm pretty sure you can operate all but silence and volume buttons on side with this case...
hello
the one i have on my bike dose let you use the touch screen and you can put a small pad lock on it as well the only time it will not work is if i have gloves i love it and use it every time i ride the bumble bee
bumble bee
kevin wisor
1999 rsv
jax fl
hello
bumble bee
kevin wisor
1999 rsv
jax fl
Cool. For some reason the iPhone won't work if you have gloves on unless they are very thin.
