poppyrodg Posted August 27, 2007 #1 Posted August 27, 2007 i was told that someone in the organization is selling extensions for the light bar to set it a couple of inches off the fairing. i've been unable to locate any. if anyone knows who may be selling them please let me know thanks poppyrodg
SteveP Posted August 28, 2007 #2 Posted August 28, 2007 Details in this thread.... http://www.venturerider.org/forum/showthread.php?t=3997
Bubber Posted November 3, 2007 #3 Posted November 3, 2007 poppyrodg said: i was told that someone in the organization is selling extensions for the light bar to set it a couple of inches off the fairing. i've been unable to locate any. if anyone knows who may be selling them please let me know thanks poppyrodg Try this guy I just got mine and it looks pretty good slowroll01@comcast.net Chuck Arbogast PO Box 653 Falling Waters Wv. 25419. Bubber aka Steve Stelter
Jerry W Posted November 3, 2007 #4 Posted November 3, 2007 Submitted by Tony Dathan. Problem: One of the common complaints about the Yamaha passing light kit for the RSV is that it mounts so close to the fairing that removing the fairing becomes very difficult requiring one to either remove or loosen the passing light bracket. Installation: When the bracket arrives you will need 2 3/8" NC x 3/4" long bolts and lock washers. I got these at Home Depot for under two bucks. Undo your light bar. Use the 8mm bolts to fasten the bracket where the light bar was and then using the 3/8" bolts bolt the light bar to the bracket. Most of us that have the bracket can now split the fairing without touching the light bar or at least just loosening it a few turns. Might depend on the actual lights you have. Basically you undo the light bar, put the bracket where the bar was, then mount the light bar to the bracket! How to get one: You can contact me at dathan@shaw.ca The price at this time is $26 US or $30 Cdn. That includes the postage as well! The following are some shots I've taken in the past! #5 shows the clearance between the back of the light and the fairing. This started as a way of my being able to clean between the light and the fairing. Taking the fairing off without touching the light bar was just a huge bonus! This is where I got mine.
