prioritymotorsports Posted May 4, 2009 Posted May 4, 2009 Hello, I work at a repair shop and had a Yamaha Venture pull in, its an '88. The class system keeps throwing an E4 error message. I looked it up and I guess it means there is no voltage coming out of the air sensor. Now, when i turn the key I imagine I should hear the compressors kick on, but I'm getting nothing. Any idea on where I can get the full class system minus the computer itself? Thanks! Zac
Freebird Posted May 4, 2009 Posted May 4, 2009 Very common. Take a look at this thread. http://www.venturerider.org/forum/showthread.php?t=493
prioritymotorsports Posted May 4, 2009 Author Posted May 4, 2009 See I ordered a completley new system....so would this still be the cause of the problem?
prioritymotorsports Posted May 4, 2009 Author Posted May 4, 2009 not new system, new class controller
Freebird Posted May 4, 2009 Posted May 4, 2009 I misunderstood. I thought you were asking WHERE to order a new system. If you have already replace it with a new one, then that shouldn't be the problem. Are you familiar with how it works? The class system only works with the key in the ACC position. You should not be getting the error code on a new system though.
prioritymotorsports Posted May 4, 2009 Author Posted May 4, 2009 Yes I have it on ACC and it throws up E4.....kinda confused...
Guest Fly-N-Lo Posted May 4, 2009 Posted May 4, 2009 (edited) If you haven't already, check connections under seat and back at the pump (under trunk). My '90 had the same issue when I first bought it. It is originally from Miami so needless to say all the connectors throughout the bike had some sort of corrosion. Also check the solder joints on the CLASS circuit board as outlined in the site tech section. Worth a try before buying a new Controller. Good Luck!!! Edited May 4, 2009 by Fly-N-Lo typelexic
GeorgeS Posted May 5, 2009 Posted May 5, 2009 Open the controller unit, Resolder the wires to the Circuit board. Also, about 4 inches from the controller, the Plug, Tug Tug on the wires both sides, one of the wire migh just pull right out of the plug. I had both these problems !! Also, the Large Plug, Under passenger seat, left side, about 18 wires going thru it, give this plug a bath with Contact Cleaner, and compressed air.
prioritymotorsports Posted May 12, 2009 Author Posted May 12, 2009 okay I resoldered the connectors and it fixed the E4 code and worked for about 5 minutes...now it's throwing an E1....any ideas or input?
mtcowboy Posted June 10, 2017 Posted June 10, 2017 I'm looking for a air compressor or a replacement one any thoughts. thx
