crazyyamaha Posted July 20, 2007 #1 Posted July 20, 2007 I found that a 1984-1997 toyota corrolla Car Quest PT# 60928 made by stant works as a replacement thermostat $12.90 is alot cheaper than the $45.00 the dealer wants:cool10: .I made the jiggler pin on it by drilling an 1/8 hole in it and installing a pop rivet shaft that was removed from the rivet unpopped cut it about 1/4 in. leaving the bulb on it stick it in the hole and swage the end over with a punch. or you probably could just install it the way it is but I chose to make it like the factory one. It works great!
