bigchris Posted January 25, 2009 Share #1 Posted January 25, 2009 can someone tell me where the tci is located on 87 venture? Link to comment Share on other sites More sharing options...
Snaggletooth Posted January 25, 2009 Share #2 Posted January 25, 2009 Remove the battery and look to the front of the bike. It'd mounted under the bracket. You will see wires coming from 2 modules. The bigger one on the right is the TCI. Link to comment Share on other sites More sharing options...
muffinman Posted January 25, 2009 Share #3 Posted January 25, 2009 It is mounted directly under the battery if you remove the air filter box you can see it on the right hand side it has 2 multi wire connectors that stick out towards the carbs. Jeff Link to comment Share on other sites More sharing options...
bigchris Posted January 25, 2009 Author Share #4 Posted January 25, 2009 Remove the battery and look to the front of the bike. It'd mounted under the bracket. You will see wires coming from 2 modules. The bigger one on the right is the TCI. thank you Link to comment Share on other sites More sharing options...
Yammer Dan Posted January 26, 2009 Share #5 Posted January 26, 2009 Jeff is right. It has two plugs that point to the rear.The right one has 8 wires and the left one six. Link to comment Share on other sites More sharing options...
Snaggletooth Posted January 26, 2009 Share #6 Posted January 26, 2009 Doh! Muffinman is right. Breather box has got to go to get to it. Now.......getting it out is a bit of a challenge. Link to comment Share on other sites More sharing options...
