Guest oldman Posted November 3, 2008 #1 Posted November 3, 2008 I had to replace my ignition now I have key to start my bike and one to open the trunks. Does anyone know if the two keys can be combine
gibvel Posted November 3, 2008 #2 Posted November 3, 2008 Get a new key blank and cut one side with one key and the other side with the other key. That way you only have one key. Depending on how you stick it into the lock it will open or operate one or the other locks. The down side is you'll probably have to mark one side so you know which side is which.
Tom Posted November 3, 2008 #3 Posted November 3, 2008 Oldman,I sent you a message that has some info..Tom
KiteSquid Posted November 3, 2008 #4 Posted November 3, 2008 Get a locksmith to re-key one of the locks to match the other...
Tom Posted November 3, 2008 #5 Posted November 3, 2008 Oldman,Here is a link that in detail shows how you can use your same key. Good Luck,Tom http://www.venturers.org/Tech_Library/index.php?action=article&cat_id=002007&id=245
spear Posted November 3, 2008 #6 Posted November 3, 2008 KiteSquid said: Get a locksmith to re-key one of the locks to match the other...
