hdroyer Posted June 23, 2007 #1 Posted June 23, 2007 1984 yamaha venture royal wire harness, fit an 1983 venture Dale
muffinman Posted June 23, 2007 #2 Posted June 23, 2007 Dale go to bikebandit.com and look up the part nimbers for both I know that the royale and standard are different for the same years but not sure of year to year. What section of the harness do you need?
hdroyer Posted June 23, 2007 Author #3 Posted June 23, 2007 I have a broken fuse holder I cant find one to replace it, This harness hase a fuse block $25.00 for the harness thought I could swap fuse block. Got my parts for the axel (collar) put her back togather this morning so I can ride to BMC.
muffinman Posted June 23, 2007 #4 Posted June 23, 2007 Dale check out this fuse panel to replace the one in your scoot http://www.cyclenutz.com/products/electrical_accessories/fuse_panel_relays/blue_sea_6_circuit_negative_bus_2.html this might be an easier option for you the OEM fuse holders are weak and will break very easily. Jeff
