Tank float
So I am in the process of changing my fuel tank on my 1999 Venture. Everything was going fine until I tried to remove the fuel float from the bottom of the old tank. I removed the 4 screws from the float but I can't seem to get the float out. It releases from the tank but I can't seem to find any angle to remove it. I don't want to break anything so I thought I would see if anyone out there has done this procedure. I'm not sure if the float separates at some point to allow it to be removed. Thanks.
It is a fiddly project, I found that having a replacement on hand when I did mine it helped me to visualize what I had to do to get it out. I think putting it in is easier than taking it out.
Just go easy and keep trying different angles, it will come out.
