ronjolly Posted June 1, 2015 Share #1 Posted June 1, 2015 Where can I ge a Stator not OEM?? tested Battery/putting ou 12.15 rev up eng still putting out 12.15... HELP Link to comment Share on other sites More sharing options...
ronjolly Posted June 1, 2015 Author Share #2 Posted June 1, 2015 Found one at Motorcycle Super Store 06 RSTD $144.86 Link to comment Share on other sites More sharing options...
Flyinfool Posted June 1, 2015 Share #3 Posted June 1, 2015 Are you sure it is the stator? There are a number of issues that can cause what you have described. Link to comment Share on other sites More sharing options...
bigbobwilliams Posted June 3, 2015 Share #4 Posted June 3, 2015 May want to check the battery itself. Sounds like a dead cell. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
ronjolly Posted June 4, 2015 Author Share #5 Posted June 4, 2015 tested the elec system ..bat was pulling 12.5 after reving it up it was still pullin 12.5.. cleaned terminals .. took rectifier off checked the stator side nuttin.. put a new battery in. still the same reading.... called skydoc told him the reading.. ordered a rectifier and a stator $198. got gaskets a local Yamaha shop in Spartanburg SC. oh yea got the stator from Rick's Motorsports called them the stator will put out 40 amps 400 volts.... thanks yall Link to comment Share on other sites More sharing options...
