wbrower Posted September 1, 2008 Posted September 1, 2008 Hey, everyone - I've installed 1 1/2" risers on my 2003 RSV and of course there is sever binding turning to the right. I split the throttle switch housing, intending to remove the cables and reroute them from in front of the forks to behind the forks, but I absolutely have no idea how to get enough slack to get the cables out of the little black plastic wheel and/or how then to get that out of the housing. Any suggestions? Thanks in advance - Bill
Pilot Posted September 1, 2008 Posted September 1, 2008 You have a tensioner on one of the cables did you loosen that as much as possible. You might have to loosen or even remove the bars and play with them also to get the slack you need since you have installed the risers. I would put my money on the latter as to why you can't get the slack you need.
wbrower Posted September 1, 2008 Author Posted September 1, 2008 Hi, Pilot. No, I've not adjusted the tensioner - if you mean the barrel-nut up by the handlebars. I never thought of trying to get slack in with the bars removed again, though , so I'll give that a try. thanks - Bill
wbrower Posted September 1, 2008 Author Posted September 1, 2008 I'm happy to report success! http://www.venturers.org/Forum/images/smiles/icon_biggrin.gif As Pilot suggested, the solution was to loosen the handlebars in the risers (left risers in place) which allowed me to rotate the bars up and down as well as slide them from left to right - creating enough slack to let me get those throttle cables out of the throttle housing. It was a two-minute job after that to reroute them from in front of the fork tube to behind the fork tube. As best I can tell, the cables are coming out from the left side of the steering head and just come through now behind the fork tube. There is still some tightness that I cannot seem to do away with on the right, but it is much reduced and I'm now not worried I may be over-stressing something. Just took her for a short ride http://www.venturers.org/Forum/images/smiles/action-smiley-083.gif ('cause I'm only wearing shorts, t-shirt and sneakers -but I did add gloves and helmet!) and went around some normal neighborhood right turns with no handling issues nor throttle problems. Next step for me is to get the bumpers back in place and make a minor throttle position adjustment on the handlebar and I'll be able to call it a done deal. Thanks again, Pilot, for your help. http://www.venturers.org/Forum/images/smiles/action-smiley-030.gif I think if anyone else adds risers, they would be well served to perform the throttle cable reroute portion of the job as soon as they loosen up their handlebars from the original postion. And thanks to my son, Wynn (he's 11), for helping hold the throttle housing while Dad put the cables back in place - without using any bad words, either http://www.venturers.org/Forum/images/smiles/icon_biggrin.gif
