BigBoyinMS Posted August 9, 2008 Posted August 9, 2008 I read a tech article on another forum about how the pilots are adjusted lean from the factory. (That sounds normal) It recommended turning all four out 1/4 turn. For those that have adjusted their pilots... does that sound about right? FYI, my Venture is an '07.
pegscraper Posted August 10, 2008 Posted August 10, 2008 Yep, 1/4 turn to a 1/2 turn is probably about right.
Cutty Posted August 10, 2008 Posted August 10, 2008 Turn them ALL in counting each one and write it down before you turn them out. I've found from the factory they are set diff. The more you turn them out the richer the mixture. I use 2.5 turns out as a starting point and a road test before making a final idle adj.
Pilot Posted August 10, 2008 Posted August 10, 2008 (edited) I read a tech article on another forum about how the pilots are adjusted lean from the factory. (That sounds normal) It recommended turning all four out 1/4 turn. For those that have adjusted their pilots... does that sound about right? FYI, my Venture is an '07. Can you give us a link to the article? Thanks Never mind I think this is the article you are talking about: www.venturers.org/Tech_Library/index.php?action=article&cat_id=002010&id=168 Never can get links to work properly, so go there and look under the 2 gen area then fuel system. Edited August 10, 2008 by Pilot
migmako Posted August 11, 2008 Posted August 11, 2008 I'm new here and I have about 3 hours reading post about Carbs. I really appreciate to know what's the standart factory adjust in each carb. I need to know it to star because I just get this second hand Royal Star one month a go. Thanks in advance
