FROG MAN Posted August 3, 2008 Posted August 3, 2008 I had a spare windshield in storage for a number of years. It was stored between two pieces of cardboard held together with scotch tape. Is there a easy way to clean the tape off the windshield? A few small strips are being stubborn.
ADC Posted August 3, 2008 Posted August 3, 2008 3 things come to mind Gerald,try WD-40,alcohol(rubbing,not for drinking) or a product called goo-gone,one of those should work. Arthur
FROG MAN Posted August 3, 2008 Author Posted August 3, 2008 Wd-40 works great. Just had to let it set for about 30 seconds. Thanks.
Grandpagak Posted August 3, 2008 Posted August 3, 2008 i was gonna sugest using the grinder.. that always works.... just kiddin... glad you got it..
Kregerdoodle Posted August 3, 2008 Posted August 3, 2008 3 things come to mind Gerald,try WD-40,alcohol(rubbing,not for drinking) or a product called goo-gone,one of those should work. Arthur Be careful if you use Goo-Gone, I just removed a sticker from the the small clear lowers on the forks, I used a citrus based product to remove the glue, looks like it might be clouding up a bit now..Not sure what the Goo-gone will do, as I have never used it.. please lets us know what you used and how it worked out for you.. K
spear Posted August 3, 2008 Posted August 3, 2008 I was going to suggest a local Aussie product affectionately known as Koala P*ss! Better known as eucalyptus oil. Works a treat.
Yammer Dan Posted August 3, 2008 Posted August 3, 2008 I was supposed to have gotten a windsheild last week and guy couldn't find it..
