Seaking Posted July 2, 2008 #1 Posted July 2, 2008 I had previously mentioned having broken the left side trunk latch bracket (the vertical plate that goes into the locking mechanism).. It was a shear break leaving a flat plate of ABS on the metal part.. a clean break. I purchased some ABS cleaner and Adhesive to "weld" the piece back on.. And wow, that worked nicely! It took me longer to read the instructions on the two cans than it did to apply the product and hold it in place for 2 minutes.. Leave it sit for at least 7 hours and presto.. good as new. I actually pulled on it quick hard trying to break it again but it held. I just needed to make sure it wouldn't accidentally come apart at the wrong place and wrong time.. So.. there you go.. it works well. Thanks to all for their sage advice and comments on ABS parts repair. (Side Note: An ABS welding kit would not have worked in this application due to the way the break is located.. Welding requires a flat surface and cutting of a V Groove in order to 'weld' a bead into the v groove. I would not have been able to do this on the upper trunk latch plate.)
